- Joined
- 29 Jan 2011
- Messages
- 2
- Reaction score
- 0
- Country
Hi everyone, our vaillant ecotec pro28 has stopped working as it should, first fault, switch on central heating yellow light comes on ok fan and ignition ok, gas lights ok when fan speed increase kicks in all leds go out and display goes blank for a moment, then the sequence starts again. The radiators are warm but the hot water is cold.! When the hot tap is turned on the green led lights, yellow led lights, a second later led's go off.
Can anybody offer any advice, i've had the cowl off to eliminate the flue, cheched the spark electrode can't find anything obvious, no fault codes either. I' getting close to ringing vaillant
