Hi all,
First time poster here.
I've just moved into a flat, and have a Vaillant EcoTec Plus 428 combi boiler which was installed a few years ago. It's paired with a Triton Jade 3 electric shower unit. The problem is that the shower pressure is quite low and the hot water only lasts for 5 minutes (is nice and hot, and then just runs cold from then on).
I've looked up the problem on a few forums via post searches and have tried increasing the pressure in the system (using the two grey taps under the boiler control panel) - no effect.
I sopke to Vaillant yesterday and they said it could be an issue with the shower - as the Triton Jade 3 isn't a mixer shower unit there might be issues. I tested this by running hot water from the tap on max for around 20 minutes - pressure was fine (as much as I wanted) and was hot throughout.
Not sure whether this is a shower compatability issue, or a boiler fault? I'm thinking the former!
Hope someone can help / advise!
Best,
Ed.
Best,
Ed.
