In my open vented Y plan system when heating up only the DHW cylinder with the boiler flow somewhere around 70C the S53 code is regularly appearing if the CH is then turned ON. The system is clean, the pump is healthy (set to max speed) and flow is good even when only DHW is being heated.
I can only think the sudden inrush of cold water at the return is not quickly enough reflected in the flow temperature so the boiler thinks there is too wide a temp difference, ie insufficient flow when the opposite is probably the case.
Has anyone had any similar experience of this, or any suggestions other than ditching the Vaillant and getting an Intergas?
