Hoping someone can help please?
We've just had a Vaillant Ecotec Plus 615 installed and the electrician and installer are slightly flummoxed.
It is a Honeywell S-plan system.
There is no call for heat (0V to the 'RT' terminal) but the boiler is maintaining the flow at 75c (through the internal bypass, so with the burner modulating down very low).
I've checked with a multimeter and the output down the wire connected to the 'RT' terminal is correct (i.e. 0V when timer is off, 0V when timer is on and there is no call for heat, 240V when timer is on and there is a call for heat).
Does anyone have any idea what could be causing this?
Thank you.
Thank you.
