Please can you advise me - I have had a couple of F75 faults. Heating Engineer fixed the problem by increasing pressure (opening valve?). Having just returned from a holiday I had the same issue (F75 - non ignition...) and therefore opened the valve lever - the pressure went up into the red zone and i was able to re-ignite / power up my boiler - having gone into the red zone, I bled a rad to decrease the pressure.
What pressure level reading should I go for?
In addition there seems to be an issue getting the hot water to heat up quickly now - is this related?
Thanks!!
Thanks!!
