Hi, looking for some help/ideas re the above boiler which I installed last summer. Called out by the customer today, when DHW is drawn off the boiler starts to make a vibrating sound which seems to be coming from the combustion chamber area, not the plate heat exchanger area. Noise only occurs when under full load, reduce water temp to say 50c and all quiet, when supplying just the central heating similarly all quiet. Takes around 20 seconds for the noise to build up after a hot tap is opened. Full pressure flush undertaken on install and magnaclean fitted too. Is in a hard water area but wouldnt expect problems within 6 months. Pressures all look good. Searched the forums and cant see any similar reports. Any ideas would be appreciated, thanks
Simon
Simon
