hi
My boiler works fine for hearing water, but I'm having some problems with heating. The water flow through temp is set @ 60c but when I change the thermostat to a higher temperature it will only ever go to about 40c or so the n go less than this. My radiators get warm but the temperature never reaches what I set in the thermostat. I've tried setting it at 25c but it still just heats to about 18/19c then the flow temp either stays constant at a low40ish or drops again. Does anyone have any idea why this is happening?? Thanks
