System: Vaillant ecoTec plus 837 combi boiler with Honeywell CM900 Programmable Room Thermostat
Problem: I have recently had a Vaillant boiler and Honeywell CM900 installed in our flat. When I turn the heating on via the Thermostat, the boiler fires up as expected. However, the burner is at such a low level that it takes the Radiators about 40 mins to heat up to the 60c setting on the boiler (I can see it it's burning at a low level by watching the graphic on the boiler as well, watching the water temp slowly creep up on the boiler and obviously by feeling the radiators).
If I turn the boiler itself on and off (after waiting some time for the water to return to colder temp) and then repeat the steps above then the boiler fire up properly, the graphic shoots up to about 3/4 of the scale and the radiators heat up very quickly from cold (about 5-10 mins to reach 60c from a starting point of 15-20c). However, later on in the day when the heating comes on again it will return to its slow state and take an age to heat up.
This happens whatever temperature I set the thermostat at (i.e. if the current room temp is 14 and i set the thermostat to 16, 20, 25 etc. then it will still be the same slow speed).
Obviously this is most annoying in the morning when i have to turn the boiler off and on to get quick heat from the radiators.
I've called in the installer who has tested the system but says that nothing is wrong. Can anyone help before I have to call Vaillant?
