Ok I have changed the diverter valve and still have this problem.The original had leaked a bit and was very stiff to move.
When you turn on the hot water the motor moves as it should but is very very weak.
Running through the diagnostics the screen says that the valve is in its correct position for h/w or c/h.
In the second level diag I can set the diverter vale the motor seems to energise but the valve does not move as watched with a torch.
This is leading me to believe the pcb is shot and not sending enough juice through to move the diverter valve.
Any one out there help?
