Lost about a pint of water through loose radiator connection. Now error F22 but have no tap heads underneath to refill (there are valves on flow/return which can be turned with pliers but am unsure whether to turn these). I read the following on forum:
'Ecotec plus range needs the boiler/pcb to purge the system/heat exchanger of air by setting 'P 0' on turn on. Failure to do this could end up with an F76 fault and the only way out of this is a new primary heat exchanger'
and would like to know how i then set P 0 on turn on.
Hope someone can help...
