We have a three year old Vaillant ecoTec Plus which producing plenty of hot water but no heating. Water pressure is 1 bar. The control unit is a wifi VR 66. I have changed the batteries in the control unit and the thermostat seems to be working. Neither the boiler nor the control unit are showing any error messages.
I have vented all the radiators, the towel rails and the Fernox filter a couple of times. I can't find any external pump to vent and I am wary about opening up the boiler to see if I can vent the internal pump. I have flushed out the filter. Nothing so far has got the heating going.
One thing that I have noticed is that the pipe above the filter is very warm and the filter itself is warm but the pipes below the filter is cold. Both valves above and below the filter are set to on (parallel with the pipe) Is this how it should be?
Is there anything else that I can try before calling in the heating engineer?
