Hi Folks,
Moved into a new house 3 weeks ago (not a new build).
Previous owners had a Oil to Gas conversion done 2 years ago this week.
Copper cylinder has been removed and a Vaillant ecoTEC plus gas combi boiler fitted.
When we moved in 3 weeks ago the previous owners left a note saying "Water pressure will occasionally drop causing the boiler to go off - turn both valves under the boiler for a minute then turn them back again and it will start to work."
So in the last 3 weeks this has happened 5 times. Usually it happens overnight so the 4 kids wake up to a freezing house or while you are out for the day so again coming home to a cold house. Common denominator seems to be when the boiler is off for a few hours and it doesn't come back on and there is an error on the screen that it shut down due to low water pressure.
The instruction manual says the boiler will shut down if it detects water pressure drops below 0.5bar. Northern Ireland Water have been out last week and measured the supply at 4bar and checked that there had never been any call logged by any other resident in the area for low water pressure.
I pushed the point that it was intermittent and although measuring 4bar while he was there could it possibly drop below 0.5bar intermittently? He suggested that wasn't a possibility as 0.5bar is virtually no flow and others would complain also.
So if it's not the mains water supply what else could it be?
Thanks,
A.
Thanks,
A.
