Hi guys!!
I am currently experiencing a problem with my Vaillant ecotec pro 24 boiler. Last Friday night my boiler broke down. The fault code f.62 appeared which stands for according to the Vaillant manual "Gas valve shutoff delay" and the cause for it is "Gas valve leaking, electronics defective". The heating technician established that the printed circuit board needs to be replaced. So I replaced the circuit board. After changing and igniting the fault code f.25 appeared . F.25 stands for "Interruption in the compact thermal module cable harness" the cause is "Compact thermal module cable harness defective". I called Vaillant the suggested that the cable tree harness (Part no: 0020052332) needs to be replaced. So the harness was ordered and replaced. And now I am back to F.62 again!!! I am quite frustrated!! Whats wrong with my boiler and whats wrong with the weather!!!! It's freezing cold. Have you experienced a similar problem? Any suggestions?
