Hi, all,
I wonder if anybody can help with a problem that I have on a boiler that's about a decade old but in good condition. Basically, when I switch on the central heating, it will run regardless of the demand signal from the simple Honeywell thermostat that I have attached to terminals/clamps 3-4.
I have done some diagnosis:
- Checked for continuity on the cable that runs through terminals/clamps 3-4 and found that when the thermostat is below room temperature, there is no continuity; when the thermostat is above room temperature, I observe continuity. This is what I expect based on the diagrams provided in the manual. I don't measure, however, any voltage.
- Checked the diagnostic code d.08, which is always 1, no matter whether the CH is on or off, or the thermostat is above or below room temperature.
- Checked the PCB (from the back, haven't took it apart completely) and didn't find any obvious failures like burnt fuses or burst capacitors.
Has anybody experienced this/any idea of what I could do to further diagnose?
Thanks!
Gabriel
Thanks!
Gabriel
