Hi Again All.
After my old troublesome heating setup, I finally had a complete
new instalation with a Vaillant Ecotec Pro 28 boiler.
Despite the installers best attempts, due to the very long route outside my house,the condensate froze.
I have now (after a lot of effort, run it inside).
When it DID freeze, the condensate backed up to the stub just below the boiler. The original condensate pipe was slipped loosely over the stub.
As the water filled to the top of the pipe, it then dribbled back down the outside.
This was spotted fairly quickly and a bucket put underneath......All OK.
I have completed my new condensate run in a similar fashion.
ie, with a loose fitting pipe, NOT sealed.
Should I actually SEAL the condensate pipe so that in the event of water backing up the pipe, it will stay IN the boiler? Is there some kind of automatic shut off on this type of boiler?
How does this work? Will it just end up inside the boiler and bugger it up?
Hopefully, this should now never occur with the new condensate run but in the event of this happening, which is best?
Dribble back down the outside of the pipe or
Back up inside boiler to (hopefully) close down?
Many Thanks as always for any answers.
Ian.
Ian.
