I had a Vaillant Ecotec Pro 28 fitted in 2016 and have had it serviced each year by the heating engineer who fitted it. This year I noticed that when the hot water tap is on full the temperature is nowhere near the 55C the boiler is set at. I rang the heating engineer and he said it was likely that the incoming cold water was so cold the boiler couldn't heat it up enough and to reduce the flow on the tap. Reducing the flow to about half did indeed result in hot water ask expected. However, this has continued and I don't think it did it in previous years in the winter.
I have just tested my mum's older EcoTech Plus boiler and that didn't have the same issue... however, my sister's Ecotec Pro 28 does seem to have the same issue and my sister has had to set the hot water temperature to 65 so that their shower is warm enough.
My heating engineer is due to service the boiler this week so I wanted to check if this sounds like an issue or is it just due to 'cold incoming water'? If it is an issue what is the likely cause? The boiler is under warranty.
