Here is my situation: I have a Vaillant Ecotec pro 28 boiler that is about 1.5 years old.
When the heating switches off, the pressure drops and I get an F22 fault code and the heating doesn't come on again until I manually restart the bolier. To get it started again I need to add pressure and then the heating works again. This only happens when the temperature to be reached is lower than the actual one .
For example - The thermostat is set to be on 21 degrees from 7AM-9AM, then it is programmed to drop to 18 degrees. And that's when the boiler gets blocked. The boiler stops working , shows F22 and doesn't not switch on when the temperature is programmed to raise again.
Same when I set the timer on HOLIDAY MODE, the boiler goes into block and doesn't switch on when needed - showing F22 fault
However the pressure doesn't seem to be the REAL problem because we do have enough pressure (not much as we are in an upper miasonette but around 1 bar). Things that we have already done: 1) pumped water into the system 2) changed the sensor and the electric component. WHAT ELSE could it be . HELP PLEASE
Could it be a problem with the thermostat?
