After some advise pls. Noticed quite low pressure (0.6) on our vaillant ecotec combi boiler. Whilst at work, the wife stupidly turned the pressure relief valve anti-clockwise thinking it was the filler and the pressure dropped again. She turned it back tight and then found the correct filler loop screws.
The pressure was increased to around 1.5 but we then had water flowing from the overflow pipe outside the house.
Have we disturved the prv by turning it?
A plumber came around yesterday and seemed pretty clueless on this boiler. He hit the prv a few times and turned it once or twice.
The overflow pipe is now only dripping (even when pressure is above 1) which is a good sign, but still having to top up often.
Will I need to replace/clean the prv to permanently fix this issue?
Think the model is valliant turbomax plus (has the front flap and internal filling loop)
