Hi
Had an Ecotec Exclusive 838 installed a few months back and have had the same problem crop up occasionally - No hot water when I turn on the shower.
When I check the boiler, the digital display reads "water deficiency -waiting period", and the S54 status code is found if I press the - button. After approx 5 minutes, the display returns to normal and the shower works as normal.
Had a Vaillant engineer out a few weeks ago but unfortunately I was not in and he told my wife that the pressure probably needed topping up, which he did. I doubt this is the cause as the pressure is always between the recommended range of 1 - 2 bar (check regularly).
Has happened a couple of times in the past week and I have an Engineer visiting again tomorrow. The problem is that it is an occasional fault which rectifies itself before an Engineer can examine!
Has anyone come across this before or have any ideas that I can run past the Engineer tomorrow?
Thanks in advance.
Thanks in advance.
