I would like to upgrade my heating system (ecotec plus VMW 346/5-5 with a VRT370f thermostat) to be able to remotely control it.
I was looking at installing a VRC720f thermostat with a VR921 box and several VR50 TRVs to be controlled with the Vaillant app.
Before embarking in the full purchase, though, I’d like to find out how the system would work.
Specifically, the VR50 only operates the radiator valve or does it also send a request to the boiler (via the thermostat, I suppose) to provide hot water ?
If it is so, which device has precedence, the VR50 or the thermostat itself ?
Just an example: during the night the thermostat is set to, say, 18 degrees and in the room there are 20 degrees. A VR50 in the bedroom detects a temperature in that room that is below the set temperature. What happens ? The VR50 simply opens the radiator valve but the radiator does not heat up because the thermostat is preventing this or the VR50 actually sends a request to the boiler that is honoured and the radiator in the bedroom starts heating, but also all the other radiators that do not have a VR50 installed ?
Does it mean that to prevent this, one needs installing VR50s on all radiators, including the bypass one ?
BTW, I have seen a starter pack with 3 VR50s and the VR920, I couldn’t figure out the difference between the 920 and the 921, would the 920 work in the setup I want to install ?
Thank you !
Thank you !
