Hi All I have a vaillant turbo max 242 \282
but there's not hot water.
When I switch turn on the tap it lites up but then the ignition light flashes with no hot water.
I was told that it's been leaking slighly and the water pressure is at 0.
Had the same problem about a year ago and the plumber changed a small rubber piece(may be a diaphram washer) and charged me £150.
I've heard the diverter valve is a common problem could it be that ?, or is it this washer again.
BG want £200 to fix any boiler is it worth it, don't want to pay that if it's only a minor problem.
BTW i'm in London.
BTW i'm in London.
