- Joined
- 25 Sep 2023
- Messages
- 2
- Reaction score
- 0
- Country
Good morning everyone,
I was making some maintenance task in my house, so I remove the radiators from the walls.
Well, now I am trying to start again the boiler, but with the CH disabled (swith just in hot water).
When I try to run it, the Ignition light becomes to flash and nothing happens, except the hot water indicator demands is on.
The Ignition light blinking in the manual means:
"(A flashing indicator shows lack ofwater or poor water circulation in central heating system.)"
But I am quite sure the microswitch from hot water is being actuated since it is detecting hot water demand and trying to start the sequence (it makes some noises when I start the boiler and open a tap, but after a few seconds of noises, the ignition light starts blinking.
I don´t know if I can start the boiler without pressure in the CH circuit, just the hot water, but if i select just hot water on the selector, it sounds acceptable.
What could be my first approach? I ´ve read here about the diff pressure switch, but i really don´t know if it could be the reason
Thank you!
Thank you!
