vaillant turbomax 242E
20 Mar 2008
London
Hi
Please help!
I have a vaillant turbomax 242E boiler.
I have NO hot water, if I switch on the heating there is hot water but not on its own.
Reena
this boiler has had a problem with the diverter valve,and would be the first thing to look at. :rolleyes:
Hi
Thanks for your reply.
I did have the diverter valve changed approx. 3 years ago. Do you still think that's where the problem is?
Thanks Reena
if the boiler was fitted with the original type D/V 3 years ago then yes that,s your problem.
Its possible that the diverter valve was only repaired and not all changed.
Even if it was then it could still have failed although they usually last 4-5 years.
On your model we only replace the whole valve unless the demand switch is failed or out of adjustment.
Tony
