Vaillant Turbomax boiler wiring
24 Mar 2006
Can anyone point me in the right direction of a wiring diag for the above?
Model Vaillant Turbomax 828E.
I need to re-coonect the external heating timer that my plumber disconnected.....thanks.
terminal 3 permanent live terminal 4 switch live terminal 5 neutral
thanks.....only the timer has 4 connections plus earth........?
It might help if you said which timer you have. Does it have volts-free switching contacts (as if you'd know!)?
Danfoss Randall 103E7 with six terminals:
1 On
2
3 Com
4 Earth
5 N
6 L
1 and 2 connected to the thermostat.
2,3,4,5,6 go to the boiler......
You can see the instructions here.
The wiring is simple enough. L, N and E are connected to mains supply and the switched live from the boiler (terminal 3) goes to timer Com (3) and the timer ON (1) goes back to the boiler (4).
If you wire a thermostat in as well it goes in series between the boiler and timer, either between boiler 3 and timer 3 or timer 1 and boiler 4. Timer terminal 2 is spare and can be used to link in the room stat.
