Hi there, am seeking some advice regarding a vaillant turbomax VUW GB 242E. The hotwater when turned on does not allways ignite the boiler. Hence no hotwater, It works better if the central heating is running, but is difficult to get the bolier to fire for the HW if the heating is not running.
The DHW microswitch goes down when the taps are opened but the boiler does not fire. With the heating turned off even thought the microswitch is down, sometimes it doe not even show a hot water demand light. My question is, could the problem just be the microswitch which is a cheaper fix than a diverter valve, does it mean the diverter valve is working if the microswitch goes down, in which case is the problem with the circuit board.
I am just trying to avoid replacing parts bit by bit as I will have to call out an engineer as I dont feel confident in doing the work myself on something that has the capacity to blow up. Any suggestions would be greatly appreciated.
Thanks David
Thanks David
