J
jamesy28
Hi, I have a vaillant Turbomax VUW 242/1E boiler, the CH is working fine but our hot water is only luke warm. If the tap is turned right down do little more than a trickle it gets hot but as soon as you open it up the temp drops right down. The water temp dial on the boiler is turned right up.
I have noticed that when running the hot tap, the boiler fires up for about 20 secs, then switches off for about 10 secs and so on.
Any suggestions as to what the problem might be?
Thanks in advance, James
