- Joined
- 3 Feb 2020
- Messages
- 4
- Reaction score
- 1
- Country
Hi Peeps.
Recently my Boiler has stopped delivering hot water, (The heating works fine) and after much research I discovered that the Diverter valve was the likely suspect. So I checked to see if the microswitch was being depressed by the plastic arm when the hot water taps were open... hardly moved, certainly not enough to activate the switch....bingo I thought.
So I know I now need either a new diaphragm or entire Diverter valve. In the meantime I thought "I know, I will just operate the switch manually when I want hot water", so I lodged a screwdriver neatly in place to hold the switch down, and wouldn't you know it my hot water light came on and the heater fired up....great I thought.
But....I STILL get no hot water. So I'm thinking the diverter valve isn't there to purely operate a microswitch, it must also manage the flow of the hot water to the taps??
Does this sound correct, or might I have another problem?
Any feedback would be greatly appreciated.
