Vaillant Turbomax Plus Problem
2 Oct 2004
hello
Vaillan Turbo Max Plus 824 making loud banging when hot tap opened
The needle on the pressure guage moving when the change from heating to
hot water .
TIA
BAng as in pipes, or gas explosion?
needle does move a bit - how much?
Are you sure the filling loop is fully closed?
May be a blocked secondary heat exchanger!
Tony
SOunds like diverter valve sticking, unless it's just "water hammer" in the mains pipe.
Have you had an new parts? Some pcb/diverter combinations made a noise, but haven't heard a bang.
Thankyou ChrisR no new parts noise was from diverter valve .
Sticking diverter valves common on Turbo Max Plus ?
Hello Agile yes filling loop fully closed
Tony
Can these be unblocked and descaled diy ?
TIA
