The boiler does not ignite, neither for hot water nor heating, After a few seconds of switchingit on an 'S33' code comes up (this code stands for 'check air/flue system'). I had this problem 4 months ago, and was told to replace the air pressure switch - I did this and it solved the problem. However, 4 months later the same problem is occuring again. Would the air pressure switch develop a fault that quickly? or could it be another cause.... Any help would be much appreciated.
