- Joined
- 10 Jun 2015
- Messages
- 5
- Reaction score
- 0
- Country
Hi all, newbie here,
I have a Vaillant Turbomax VUW GB and the pressure gauge slowly goes down over the months and an engineer comes in and adjusts the two valves underneath and re-pressurises the unit. My question is - is the pressure going down normal behaviour?
Secondly, why - depending on the company and/or engineer - do they announce some other part needs replacing as the unit worked perfectly well up to then. The last engineer said the flue exiting the building needed replacing. And the engineer before that (after tapping the main gas valve with a screwdriver - and jamming it) said the gas valve was broken and needed replacing.
Reason I'm asking is that the pressure gauge went to zero on Mon and I got the engineer in and he turned on the hot tap and then said the entire unit (pointing to the pressure gauge) needed replacing. I pointed to the two valves and said that's all need adjusting. Which he did and pressure is now at 1 BAR. Are there any honest gas engineers left out there?
