Hello,
Am new to this site and need some good help - Please.
I have a Vaillant combi boiler and the ignition light (the one that looks like an egg-timer) is regularly flashing yellow.
I have to press reset and then it sometimes fires up immediately and then once again there is constant hot water & heating.
Other times I have to press reset a few times before it fires up again and stays constant yellow (rather than flashing).
It happened this time last year, which makes me think it is something to do with the cold weather ??
The manual says it could be that there is not enough water in the system. But there is. I have tried to add a bit of water, but then if I press reset, there is the most awful clunking sound and the pressure dial swings violently to the right (maximum), gets stuck, and only when I quickly turn off the boiler, does the dial then slowly fall back to where it was positioned before. It is quite a frightening sound. Makes me feel like the whole boiler is about to blow up or fall off the wall
Does anyone have some advice on what is happening ?
And what I need to do ?
The boiler was fitted in Dec 2000, so it is obviously not new.
It services only one bathroom, dishwasher, washing machine and kitchen.
I really need this boiler to be working properly.
Thanks in advance.
Thanks in advance.
