Hello engineers
Got a problem with the above boiler not firing up. A mate brought a house which had been empty for about 5 months so boiler was not used in this time. I changed the rads for him and all seemd to work fine for a couple of days. However tonight he tried the hot water, worked fine for a few mins, then boiler shut down. Turned on heating, again fine for a few mins, then boiler shut down again.
I've tried the manual reset several times, works for a few mins then shuts down again.
I have noticed that on the pressure gauge, the temperate dial does not appear to work, its been like this since the house was purchased. Even when the heating was on for several hours yesterday, the temperature dial did not move at all. However i was able to control the temperature of the central heating using the heating control dial on the left of the boiler. Could the temp guage be whats causing the boiler to shut down?
Here is a pic, i have drawn the white arrow
Any tips on what I could try to rectify this? had a read online and it sounds like it may be an issue with the gas valve, in which case need to get an RGI out. But would like to try any other fixes before I do this.
