Hi, My old bolier a VUW 242 Turbomax 1/e has stopped firing today. Just checking to see if anyone has any ideas on it as most people are not that familiar with these older boilers any more. Any help/ideas/suggestions will be highly appreciated.
When I switch on the bolier, the green power on light comes on as normal. When I turn on the hot water or the CH, the normal sequence of lights come on up to the yellow fan light. I can see sparks of the ignition in the chamber. After a few attempts at ignition, the sparks stop and all the lights except the green power light go off and the boiler fails to ignite. The green power on light now starts flashing continuously. If I turn the power off and then on again the green lights again comes on as normal (i.e stops flashing) and I go through the same process with the boiler failing to light. For some reason it seems as though there is no gas reaching the system.
Please help. many thanks in advance.
