I have a Vaillant TURBOmax VUW 242 combi boiler - approx age 10 years old.
In the past few months we have noticed when having a shower that the boiler will kick in and out at random; sometimes when water is being drawn elsewhere in the system (e.g. tap, dishwasher, washing machine etc.) or, more often, when there is no other demand on the system. I have cleaned the shower head and removed a flow restrictor on the shower which worked for a short period, but the issue returned. When the water goes cold, there is a noticeable drop in flow on the shower.
My gut feeling based on research here is that the diverter valve is faulty. Any comments or agreement on my conclusion?
Also, we noticed a blown radiator in our system last week - when I checked the Bar reading, it was at 3 bar and it was clear outside that the pressure release valve had kicked in and water was leaving the boiler via the overflow. Having reduced the pressure at the system release valve, the pressure only seems to increase when the central heating is on.
Again, based on research on this forum this seems to suggest that either the cold feed loop is leaking or that Heat Exchanger may be leaking. Given that a new loop was fitted in the last two years it would be unlikely that this has gone, and given the age of the boiler, it seems the heat exchanger is more the likely suspect. Again, any comments or agreement?
Finally, online prices seem to suggest a diverter valve and heat exchangers are in the range of £70 ea. How much should I expect to pay for labour?
Thanks in advance - would like to get this sorted before Baby No. 2 arrives in the next few weeks!!
