I recently had to change the DHW heat exchanger and now the heating is very intermittent, it just runs cold, the heating pump is running and warm for long periods, but the radiators stay cold.
Also a question about the kit to change from the plastic to the metal DHW unit, it asks you to cut a link on the circuit board if you have a hybrid board, how do I know by looking at it if it is indeed the hybrid?
And in the kit was a brass disc with a rubber washer on each side, where does that go, as there is nowhere in the DHW diverter valve assembly, as I have opened that up to check.
Mike
PS the unit is of unknown age as it was in the house when we moved in.
The copy of the wiring diagram in the lower cover states
VCW GB242E, 282E 80 65 46 GB 04
Mike
