having some trouble with my Vaillant VCW 242 EH losing pressure in the CH part, needing topped up about once a week at the moment. I top it up to about 1.5 bar, then the CH runs and the pressure goes up to the max while the CH is running. Once the CH stops and the system cools down the pressure has dropped a little, until after 5 or 6 days its under the 1 bar line and I have to top it up (although it appears to run fine if I don't notice its gone under the MIN line).
I've done some reading about, and I think it might be the expansion vessel needing re-pressurised - does this sound right? If so, there is a red tank at the back of the boiler which i presume is the expansion vessel, and at the top right hand side of the boiler (but not obviously a part of the red tank) there is a small chamber with what looks like a car valve in the top of it, with a cap with a hole in it on the valve, and the cap isn't screwed down tightly. Is this the valve i need to re-pressurise the expansion vessel from, or is there one actually on the vessel itself?
Any advice appreciated.
