Hello there,
I've just moved into a 'new' house that has a Vaillant VCW GB 240 H combi boiler. The boiler works fine for heating but hot water in the taps is not working properly.
If the heating is off and I turn on a hot tap, the boiler kicks in and the water warms up just a little but doesn't improve beyond lukewarm. The shower is very cold and barely heats up at all. I've been doing some searching online and some comments here suggested that the diverter valve may be responsible? I asked my other half to leave the shower running, the boiler stays on, the water from the shower stays barely tepid and she reports that the radiators don't heat up any.
When the heating is on and the radiators are hot, when I turn on the tap in a sink the water comes out quite warm. The shower starts off hot and then cools to a luke warm temp. If I turn it off for a minute and then restart it, the shower is warm again before cooling down.
Using my highly scientific jug and basin I get about 10l/m flow rate if that information is any use.
Any ideas on what I can do to repair this or if is even possible to repair? It's really old and information about it has been scarce. I've been quoted anywhere from £120 to £280 for an engineer to come and take a look at it which I'm loathe to spend unless there is some hope of repair. Does anyone have any recommendations for an engineer that is familiar with these boilers that might have more success than someone who has never seen one? I'm based Swindon.
Also are there any suggestions for how I could diagnose what the problem is. If I could identify the source of the problem there is a chance that I could find the part and get an engineer to replace. Any tips or information gratefully received.
