Vaillant VCW GB 242 / 282 EH problem with the hot water.
19 Nov 2005
Surrey
The hot water setting has been wrong for a while, the hot water temperature fitting broke internally when I was last trying to get it to move with some pliers.
Bought a replacement part, 01 - 2533, now all I did was turn off the water, open a hot water tap till the pressure was gone and replaced the assembly. Now the MINIMUM flow rate I can get from the kitchen sink tap is 70 secs for 10 litres, sort of annoying but not a show stopper, BUT each time the hot water is used the lever arm vertically above the flow rate adjuster keeps popping all the way up, and it takes quite a push to get it back, then the gas and pump will turn off.
What should I look at first?
Mike
