I have an old Vaillant VCW GB 242
I developed no hot water unless I activated the servo switch manually, as a result I took it apart and have now fitted a new diaphragm as the old one was shot and also a new servo valve.
Fine I thought, put it back together but the thing would not ignite.
Been reading all over the net and have found two things that have been of help:
I did this and the thing fired up with ridiculously high flames. In the manual it also suggests fitting a tube to the test point (to the left of the tube mentioned above) and sucking. The same thing happens.
So I guess that the problem is indeed the 'air pressure switch'.
Any ideas on part numbers or anything else to look at before I order the part and get one of the guys in work to fit it?[/quote]
He phoned Vaillant again and they then said take off a tube at the back going into the combustion chamber and blow down it, softly first then hard, if flame profile increases when blown hard it’s definitely the ‘gas section operator servo’ on the main gas valve.
