hi just come home from work and i have no hot water.the boiler is a vaillant vcw sine combi.the boiler fires up when i open the tap but the water doesnt get hot i tried the centrall heating and it works fine any help would be most appreciated cheers.
Very high chance that the flow switch on the left hand side of boiler has a fault . It has a wax capsule in it that makes the insides of the valve move from heating to hot water .
Old boiler now, so parts may not be avialable capsule was about 20 quid and whole valve about 150
Remote possibility that it is the calorifier but these where bullet proof
hi thanks for your replys i have just noticed that when i swith the heating or the hot tap on when the boiler fires up the flames arent going very high could they be stuck on low flame or something?
