I have a Vaillent turbomax combi that goes to lock out on first start up from cold either on heating demand or hot water demand. Once manually fired up it will continue to stay on while heat is called for on the timer. In other words it only goes to lock out when system is cold. The system was serviced last August and it has worked fine since as it has always done. An engineer came out last week who couldnt find a fault but replaced a micro switch but the problem is still occuring.
Any advice or thoughts would be greatfully appreciated before I call out the engineer again and face another £80 call out charge
