I have a Vailiant 430 and today for the first time I turned the heating on due to it being cold. I found that after a while the heating was remaining on despite the Nest having been switched off. I went to the boiler and found the radiator symbol flashing which I understand means its active. I set the default base temperature on heating down to 65 and sure enough, it went off and the temperature dropped at the boiler. Once the lower temperature was reached the boiler kicked back in again. I reset the boiler by way of a full power cycle but still, it fired up. I removed the Nest from the cradle and re-plugged it back in and things now seem to be OK.
I'm thinking the Nest unit must have been stuck on despite saying it was off, anybody any idea?
