ok so we are currently having our boiler replaced with a new 618 system boiler plus unvented tank and the wireless stat 350f for control.
Question is:
Regarding immersion, 3 port valve and tank stat is the only feed I need between the boiler and wiring box a 4 core to carry SL, PL, N and E.
And should the SL be straight from the boiler and the L, N and E be from the 3A switched spur feeding the boiler supply?
All the rest is wired via the wiring box?
All slightly confusing valliant manual isn't very exhaustive re pin connections etc and trying to work it out.
Thanks to anyone that relies will be very much appreciated as really scratching my head at the moment ha ha
Paul
Question is:
Paul
