MY BOILER IS NOW ON 0 PRESSURE AND THE MESSAGE STATES, NO WATER IN THE SYSTEM. IS THIS A MINOR PROBLEM OR CAN I RESOLVE IT QUICKLY? CAN ANYONE HELP URGENTLY
If its a plus version there are two taps underneath the boiler turn them both on check the pressure by pressing the bottom left - button when the pressure is around the 1 to 1.2 turn off both taps if the boiler does not spring into life press the reset button top left job done. plonker Ive just seen the date argh.
