valiant boiler not igniting
30 Aug 2006
Glasgow
hi, I'm not too clued up on bolers or plumbing, I'm a joiner. I had made some alterations to my house which required moving some radiators, my boiler has been switched off for roughly 3 months. today I filled up the system again and after running round like a madman trying to fix all the leaks I finally got the pressure to stay up. all the rads have been bled and everything seems ok.
only problem is it now wont ignite. When i switch it on i can hear the igniter sparking for about 10 seconds before it shuts down withgout igniting. when i press the reset button it sparks for 10 seconds before shutting down again. I've tried now about 20 times with no joy
any ideas?
its a valiant VC GB 182 E H
Have you turned the gas back on? There's a little isolating valve on the middle pipe under the boiler. Otherwise it may be the gas valve sticking shut after being unused for so long. A gas engineer could check this for you.
Im sure all the other lads on here will sort you out soon..But i will just state the obvious, IS the gas turned on. :?:
Whereabouts in Glasgow?
Whil;e you might ave removed air from the radiators, boiler also needs to be purged. Thre could be other issues with boiler not having worked for several months. It is the water that makes this boiler work
Check your boiler again, you sure it is 182?
i'm actually in paisley....
i'm pretty sure its a 182. the sticker on the underside says VC GB 182 E H compact boiler cat 1N cat C1
yeah the gas is definetly on. had to double check tho :LOL: and the isolating valve on the middle pipe is open
how do i purge the boiler. I've not done that.
