- Joined
- 4 Dec 2016
- Messages
- 4
- Reaction score
- 0
- Country
Hey people,
I had a quick look at this site for the issue I'm having and I found this page:
//www.diynot.com/diy/threads/valiant-ecotech-pro-28-drayton-digistat-3.228065/
I had a custom heating control system installed and I'm looking to revert back to the original from the house now that I'm moving.
I have a Valiant Echotech Pro 28 boiler and a Drayton Digistat 3 that I want to get back installed to it.
The cabling in the wall is still there and correct. I've tested that if I bridge/short the two cables at the Digistat end, the boiler stays on constantly, so the cabling looks good.
However when I wire in the Digistat it's not triggering the boiler.
Is there a way I can test the Digistat? My logic would be if I put on the heating on the stat with it off the wall and on it's own, surely it should bridge two pins on the back of it, which I can prove with a continuity test on a multi meter? There seem to be two pins constantly bridged even when the heating is set to off - is this correct?
Which pins on the stat should correspond with the boiler? What I've read is 3 to common and 4 to on?
Thanks in advance.
Thanks in advance.
