Hi
I have a Valiant Turbomax 282. The central heating works fine. The hot water works when the CH is on. But when the CH is off the hot water only comes on some of the time. If we reset the boiler (by turning the central heating control switch to the reset (flame) position) the hot water works but this is needing to be done more and more often.
By looking at the diagnostic LEDs everything lights up sequentially up to the point of Ignition Indicator but the Flame Indicator LED doesn't come on. After 10 seconds the Burner Lock Out Indicator LED comes on and switches of the boiler. If I reset this then the boiler fires up ok most of the time.
I suspect there is a problem with the control board but any ideas or suggestions would be most appreciated. If it is the control board does anyone have any ideas on the price of the board and good places to buy it from.
