- Joined
- 11 Sep 2016
- Messages
- 3
- Reaction score
- 1
- Country
I have a vaillant turbomax boiler quite old probably 15 years old.
I had an engineer come round to clean the heat exchange because I've had problems with my hot water.
but I still have the same issue. best suspect it might either be the flow switch or some other issue.
they don't suspect it to be the heat exchanger because of the water that comes out is very hot. once it's hot and gets going the temperature remains very hot. when I turn the tap off and turn it on again there sometimes is a dip in temperature. when I turn the tap on on I don't get the signal that the boiler is firing up to heat the water up. it is intermittent and random. I can leave the hot water running for a long time over 5 minutes and no change in temperature. when I switch the tap off and on again I might get hot water. the radiators get hot with no issues there is not a problem with the radiators.
now if it's not the heat exchanger because it seems to have been cleaned quite thoroughly with acid, and because I'm getting a very high temperature as per usual I was told by the engineer that if it was a heat exchanger issue the water would come out lukewarm and wouldn't get hot as strongly as it does.
does anybody have any idea what the issue could be?
