I've read a number of threads and, whilst there are number of similar faults listed, I can't find anything that matches my symptoms exactly.
My boiler has recently developed a fault where the domestic hot water alternates between hot and Luke warm. The central heating works fine.
When running the hot water the boiler fires up for about 10 seconds then stops for about 10 seconds before it fires up again. This cycles continues for as long as the hot water is running.
I don't think it's the diverter valve because the feed and return to the heat exchanger get hot but not to the heating. The status codes cycle around: S.11, S.13, S.14, S.16. The diagnostic codes: d.24 and d.30 cycle between 0 and 1 as the boiler fires down and up. Codes: d.10, d.22, d.35 display 1 throughout.
When the heating is on the status codes show: s.0, s.1, s.3, s.4 and stays on s.4 until the room thermostat turns off the heating. The diagnostic codes: d.10, d.22, d.24, d.30 = 1; d.35 = 0. As expected I believe.
Ideas?
Many thanks
Ideas?
Many thanks
