I have a Valiant Turbomax plus 82X E that has developed a problem in that it does not always switch between hot water and CH. If the CH has turned off for the day, and then I try and run the hot water it runs cold, or visa versa. I can temporary fix this by switching off the boiler and back on again and it works OK till the next time. The problem does seem less obvious if the CH is on, then running the hot tap is OK. I've checked the diagnostics, and it says the divertor valve has operated, but whether this is the case??
Any help appreciated.
